sealing control surface
Scotch Tape. Holds well believe it or not to any Kote type covering, I had the same strips of tape on my Avistar's elevator for over 30 flights before the oil started to effect it's adhesion. So I just removed it, wiped the area down with some rubbing alcohol, waited for the section to get dry and stuck some new tape on.
