RCU Forums - View Single Post - Fuel question
Old 07-31-2004 | 12:02 PM
phread59
Default RE: Fuel question
Paul, yes you can put oil in the fuel. Just be sure it is lube designed for a methanol base. most oils out there sold commercially are for petrolium bases. Castor oil would be the stuff to use. I just do not know if there is castor for methanol and petroluim. Or is castor good for both. I am not sure. So just be careful what you add. Good luck.
Mark Shuman
