RCU Forums - View Single Post - Duralite Users, I have a question
Old 07-31-2004 | 08:50 PM
TonyF
My Feedback: (92)
Default RE: Duralite Users, I have a question
It's very important that the regulator is not plugged in between the battery packs and the switch. If it is, the regulator will pull a small current out of the battery until it is dead. If the pack gets below a certain voltage it will be damaged.
The voltage regulator must be installed between the switch and the RX. That way when you turn off the switch the battery pack is isolated.
Hope this helps!
