hole
What's the inside look like?
If it's torn-up all the way around the bottom, it's likely the rear bearing went south - there's not much clearance and you should be able to feel the slop in the shaft.
If there's no damage other than the hole, it was probably a void in the casting.
Either way, it should be covered.
Kirk
