RE: Thrust calculator
Yes,
Measuring and comparing the propellers' static thrust won't give reliable results, as the blades of a given prop may stall showing bad static thrust at the test bench, whereas it may show excellent performance in the flight and even outperform other ones that show a better static thrust.
