RE: TRUCK WONT START!
Try adjusting the low speed needle valve. If that is set too lean, the engine will hesitate and die at idle. This condition will also make it hard to start. Try turning up your throttle trim when trying to start it. It's a good idea to set the unit on something to keep the wheels off the ground. Good luck.
