RE: What will happen if you do NOT cut the red wire on an ESC when using a BEC?
Just pull the pin and wrap it with a little tape to insulate....
Using the UBEC and internal BEC is bad mojo....the UBEC will constantly try to make up for the voltage drop of a linear regulator...
