RE: Suggestions for first build
I've built the Uproar, and I think it would be a great first kit. It is an easy build and very cheap. It is also extremely light. With a TT46 I have essentially unlimited vertical performance. It is very responsive (especially the ailerons) and will go where you point it, so you will really need to dial down the throws to make it a suitable second plane. If you build the Uproar I would point out two things to consider. I think the rudder and (to a lesser extent) the elevator areas need to be increased. The other is to point out the fuel tank compartment is restricted. I had to go with a 6 oz tank. If I build another (which I may very well) I will be looking for a way to increase the depth of the compartment to hold an 8 oz tank.
