RCU Forums - View Single Post - Avistar conversion
Old 08-01-2004 | 04:10 PM
3dandpatternflyer's Avatar
3dandpatternflyer
Default RE: Avistar conversion
Whatt meter shows 228 whatts 32 Amps on 8 cells with 14x7 APC prop. He will test fly it tomarrow or later in the week. He says he had to change to a Griffen 55 and a seperate Rx pack to get four min of run time the GP SP control was cutting out from the heat. The Griffen Bec couldn't handle the 2 full size and HS 81 and kept cutting out. Weight just under 5 lbs.
