RCU Forums - View Single Post - engine very hard to start - SOLUTION FOUND
Old 08-01-2004 | 05:27 PM
TLH101's Avatar
TLH101
My Feedback: (90)
Default RE: engine very hard to start
Check the filter screen in the carb, under the cover with 1 retaining screw. It is a very fine screen and will clog after a time. Also if you have not done so, replace the plug. Sometime a weak plug will not fire as hot under compresion. Be sure to use the correct resistor type plug.
