JR1OX programming questions
Is there any way to reassign the right slide lever(aux3) to operate aux 4 or aux 5?
The 10x uses only the first 8 channels for failsafe/hold operation.I need to use the right slide lever to operate brakes ,but I cannot tie up aux 3 for brakes.
Aux 1 is used for flaps and aux 2 is for right ail(crow). I want to put my smoke system on Aux3 (mixed to snap roll button for use and also
for visual failsafe indicator.)
If slider cannot be reassigned,then how about aux1 (flaps ) reassigned to aux 4/5?
I thought I read that aux 4/5 are not 1024 but 512 (lower resolution).This may not be a problem on flaps ,but what happens if/when failsafe occurs on aux4/5?
This is on my Kingcat and I've finally run out of channels!
Thanks ,
Jake Bruckler
