G-62 Velocity Stack Question
First try the carb extension the way that pcm says. That's the normal way. But if you still have trouble, you may have to turn it around a bit. The airflow is different on each plane and you may even have to put the long part to the front?
Make it run correctly.
Good luck,
Jim
