RE: BVM Wheel Screws is there a trick?
R-A,
No need for a drill press. This is what I do all the time: Use a pin to open up a tiny hole going from one side of the rim through the other. Play with the pin a little bit so that it comes put the threadded hole. Then use that pin hole as a guide, and insert a small flat head precision screwdriver to open up the hole.
It took me about 30 minutes to do all 3 F-16 wheels.
Good luck!
