RCU Forums - View Single Post - Pull-pull setup
Old 08-03-2004 | 06:39 PM
the-plumber
Default RE: Pull-pull setup
Because the line tension puts an additional side load on the servo bearings above and beyond the load reflected from the flight control surface.
Using a tiller arm (bell crank) eliminates the line tension loading and allows the servo to deal with the normal loads for which it was designed.
