RCU Forums - View Single Post - Flutter problems and Mechanical linkage Setup Lesson Learned
Old 08-04-2004 | 07:42 AM
  #38
DTB's Avatar
DTB
My Feedback: (15)
Default RE: Flutter problems and Mechanical linkage Setup Lesson Learned
ORIGINAL: Doug Cronkhite
Can someone measure the root chord, tip chord, and span of the aileron on the Funtana 90? I'm at work and can't measure mine. I want to show you guys some hard data on forces required for this, but I need these measurements 1st.
Thanks..
I am at work, but if I remember correctly the aileron's root is 5.5", tip is 3.5" and 28" span. I think I remembered correctly.
