RCU Forums - View Single Post - H9 CAP 232 1.20 wing alignment problem
Old 07-23-2002 | 05:19 PM
GalenB
My Feedback: (18)
Default H9 CAP 232 1.20 wing alignment problem
Hello,
Has anyone had trouble aligning the wing on their CAP?
When I place mine in the saddle and square it up to the former that the dowels go through it measures a 1/2 inch difference between the tailpost and the end of the aileron on each side. When I adjusted the holes and the back of the wing to get very close measurements there is a noticeable angle between the former and the leading edge of the wing and I have unequal gaps between the sides of the fuse and root ribs. The fuse appears straight and when I have equal measurements between the ailerons and the tailpost I also have equal measurements between the wing tips and the middle of the firewall.
Before making anything permanent I was hoping to hear what others had done, or what others with a similar issue on a different model had done.
TIA for your help.
