RE: u-can-do 60 II
Joe, Your recommendation is how I tune also. This is my second Saito my first was an FA 120 on a Four Star. I know how to adjust the valves so that should not be a problem. I am glad that we both use the same procedure. The tach readings would help so I know where to go after the regulator gets plugged in.
David, Give It Up!! I can't guess on the manufacturer as I don't recognize the color scheme. If you decide to come to the U.S. for Roger's contest, make sure I know. It is a reasonable drive for me as long as a place to stay over can be found. Maybe Roger could help us with that. I'll bring my Dynaflite Decathlon gasser for that one.
