RCU Forums - View Single Post - UFO rocks back and forth
Old 08-04-2004 | 09:38 PM
Flypaper 2
Default RE: UFO rocks back and forth
Another option you might try is bleeding air through tubes, out to the sides and front and back, with gates to control the airflow. The Harrier uses this system for zero airspeed stability. Yours looks somewhat like the fullsize Avro Saucer from the 60s. If you look that up on the net, you may find more ideas.
