RCU Forums - View Single Post - Rich Fong's air bubble solution
Thread
08-04-2004 | 11:14 PM
52
dbarrym
My Feedback: (
47
Oct 2003
1,346
1 Post
Carlsbad, CA
RE: Rich Fong's air bubble solution
I just built a couple of the "Eddie Weeks" style pleated paper filters using an 8 oz. round Sullivan tank and found a couple of Fram paper filters at a local Pep-Boys store that fit... here's the the Fram part numbers for reference:
1" Long for small (4-6 oz) tanks: F10157, $1.59 ea.
2" long for 8-10 oz. tanks: F10158, $1.99 ea.
Assuming that the comment that the paper filters will supply fuel even if the filter is 95% exposed to air is true, the long filter seems to be the way to go, allowing the header tank to be drained almost completely before running dry. I Aeropoxied the pickup tube to the filter after removing the one-way valve/rubber fitting...found that the filter fit much easier into the tank neck after using a belt sander to grind the rough edges/"bulges" off of the metal ends of the filter (wrap the filter element with tape to keep any metal particles off of it).
Barry
Reply
Like
dbarrym
View Public Profile
Send a private message to dbarrym
Find More Posts by dbarrym
View iTrader Profile
