RCU Forums - View Single Post - Pizazz
Thread: Pizazz
Old 08-06-2004 | 11:33 AM
JimRoss
Default RE: Pizazz
I use a Futaba T6XAS with ailerons hooked up on Ch 1 and Ch 6 (2 servos). This allows flaperons and mixing with elevator. I use dual rates and elev/flaperon mixing as set up in the program on the radio. I don't really know how to tell you how to set up a Hitec radio. Are they compatible with Futaba?
ORIGINAL: danorris
Jim, I just picked one of these up with a NT 46 installed. I use a Hitec eclipse transmitter--could you talk a little more about your transmitter set up for ailerons and elevator on the Pizzaz? By chance, do you use an eclipse transmitter? If so, I would like to try to duiplicate your program as a starting point.
