RE: Pizazz
Thanks for the response on the hitec setup.
Do you ever use flaperons in the "up" position for 3D acrobatics? Is there an occassion when you want up elevator and down flaperons? Up flaps and up elevator or down and down?
Is it important to put in exponential on the main control surfaces for the pizzaz? If so, how much do you like to use?
Obviously, I'm a novice at 3D flying. So, please ignore my questions if they ort too far off the wall. I probably just need to find a good source for 3D setup and basic maneuvers. Appreciate any suggestions you all might have.
