RCU Forums - View Single Post - BME 44 Idle
Thread: BME 44 Idle
Old 08-07-2004 | 06:19 AM
Jemo's Avatar
Jemo
Default RE: BME 44 Idle
If you think the needles are set and you have enough cooling. How is your ignition battery, you said this started after two flights, have you checked your battery at this time ??.
Has the ignition timing ever been changed from the factory setting ??.
