RE: Keeping Nylon Bolts In Wings
Steve,
Actually, if you raise the back of the wing, you introduce more negative incidence.
I have used flat rubber faucet washers on a couple of planes, that had enough space between the wings and mounts. I have also seen one plane that used small steel "E" clips, or "C" clips(similar to external style snap rings). They are thin and will work well also.
