RE: Evo .45
As the tank burns down, the engine will run leaner and leaner so if you set the engine to max lean at the first of a tank, it is going to be over lean and maybe stop toward the end of the tank. It is also true if you set the engine to max lean in level flight, it will run over lean in a steep, or vertical, climb.
