RE: Walbro with the same needles, and odd settings
this is what happens when the low is set first if the high is not open far enough in the first place...The low needle is open too far...open both 2 turns, adjust the high first....The low will be open too far, lean it out until the transition is gone, then open a little at a time until the transition comes back....
