RE: DA's New Engine
You can use the original carb if you can drill out the fuel passages slightly.....A WT499 carb comes with the glow G23 and works without modifications on gas OR glow fuel..Walbro doesn't make a carb specifically for glow engines..The 499 is used on some other Zenoah engines....
