RCU Forums - View Single Post - EMWH 2M Funtana PRO!!!
Old 08-09-2004 | 01:24 PM
olympus_86
Default RE: EMWH 2M Funtana PRO!!!
Hi,
Here's the update. Between working the midnight shift, sleeping and living life this is what I have completed. Remounted the engines on aluminum bars (the elastics were to flimsy, the engine barely idled because it shook so much) mounted the throttle servo with a rubber connection. This will absorb shock and reduce servo damage. Inside the rubber are carbon rods from both ends and in the middle is a gap of 5mm which gives a bit of flex Also mounted the ignition. The good people at KS Germany are building me a custom manifold for my SM 30 with a flex pipe in the middle and they advised me on buying the 70cc muffler because it is very quiet and it's performance will be almost exaclty the same as on a pipe. I also covered the wings on the weekend. Those silver stripes tested my patience![:@] I attached pics.
Enjoy
Sebastian
ID:	162092   Click image for larger version
ID:	162093   Click image for larger version
ID:	162094   Click image for larger version
