RE: Funtana 90 and 3D Airplanes
for a little bit of help on you problems on the 40 and 90 restlessrock you may want to do a curv mix on the plane say a snap spoilrons bothe the futaba 9C and 9Z and the JR8102 and the JR 10X are more than capable of doing it. simply use a curve mix so than when your elevator moves past 3/4 of its max travel rate the spoilerons snap up 25-30 degrees al the mauals elaborate on curve mixes and how to use them the 9C and the 10X are the easiest to do it with but it improves elevators to almost no wing rocking and harriers to solid flight lines works well on parachutes and walls too also make a switch so you can do inverted harriers so you will have them snap like flaperons but your inverted so their now spoilerons. Try thay and see it that dosent inprove your planes performance cause i simply find the funtana 90 and 40 to be the best 3D planes on the market for their size. i love them so much i want hanger 9 to make a bigger on. have fun
