ORIGINAL: bentgear
DTB, got any string trimmer line laying around? That, a drill bit, and some CA works OK. If not I do. If Hitec ever sends my programmer back we can cycle your servos on it.
Ed M.
Thanks Bentgear, let me know when it comes in. We can cycle them with your programmer. I was going to use my cycle program on my 9C, but if the programmer will do it, then that works for me. Would that be a bad way to do it using the 9C? Never had to cycle servos before.
ORIGINAL: STEVE LENZ
I used aluminum strut material (LHS) across the bottom 3/8''- used small screws to bolt on as well small sheet metal in the bottom of fuse. It is working ok in my funtana 40. On the top laced Teflon coated line in two places from horizontal stabilizer through stab . Tried to keep it as light as possible.
Thanks Steve, do you have any photos of your setup? I would really like to see the setup to get a visual of it.
DTB
