RE: Fuel Filter
John:
I've never seen the need to use a clunk different from the one that comes with the tank.
I do look at it, some aren't drilled straight through. When I see that I will make it's hole the same size all the way. Probably doesn't make any real difference, but at high flow the sudden increase in diameter could cause turbulence there, and restrict the flow somewhat.
Bill.
