RCU Forums - View Single Post - Avistar RTF assembly (epoxy question)
Old 08-10-2004 | 09:32 AM
artandscience
Default RE: Avistar RTF assembly (epoxy question)
I think I'm the fellow who suggested epoxying the two wing halves together (I had to do that on my Avistar). But don't epoxy in the horizontal stab. I just put four small dots (one at each corner where it meets the vertical stab) of CA to limit the movement (it will eventually come loose with only the two small metal rods securing it in place). Either that or get creative and cut some brass tubing to length and run that through the holes that the rod will run through (you'll see what I mean when you get it).
I think you want some flexibility in the horizontal stab (some give) so that WHEN you crash it won't just snap..
But then I'm new at this whole thing...
