So basically what you're saying is that the wing chord is the shortest distance from TE to LE regardless of sweep or taper correct?
It does not work that way. Using the first explained method the chord line HAS to be 90deg to the LE. that is not necessarily the shortest distance to the TE from that point.
Isn't this fun?
Ed S
