RE: Rambler-45 second plane?
Sorry could not find the one in flight but I took this when i was
setting up and balancing. I did switch to a side mounting for
the engine as it was easier to work on at the field. the engine
is a 65 ASP four stroke which has been excellent in fact more
realiable than my OS believe it or not. It uses a 13x6 prop.
the only other mod was to change the foam wheels for a
rubber set being a bit thicker helped the set up of the retracts
look in gallery
fly well
