ORIGINAL: crazystix
Will thinning epoxy w/ alcohol slow the cure rate? I'm trying to put a horiz. stab on & only have 5 min. epoxy, which doesn't give me enough time to make sure it's on straight (this time). thanx
No. You need to get some 30 minute epoxy. The 30 minute epoxy is less brittle and typically stronger than the 5 minute.
