RE: Ram 750F case pressure
The max CP (Compressor Pressure) that the stock 750F was set for was 1300 mb. This would vary quite a bit at max throttle as the closed loop system adjusted itself. I had two 750Fs that were set to 1400 mb max for higher output, but stock was 1300.
