RE: Have YS 63, need plane
Global Freestyle. I had one and it flies a little better than a Seduction Freestyle if you are wanting a 3D plane. YS 63 will haul it around just fine (I used mine to break in my YS63 before putting it into a Seduction FS). It will also fly the pattern stuff with reduced throws. The only drawback is the same problem you probably had w/ the Seduction, adequate ground clearance with a 13 x 6 prop. Do a search in this section and you will find a bunch of info on it. Not a bad plane for the price.
