RE: Reception range problems
The first thing you should change is the battery, they take the worst abuse in a crash for where and how they are mounted. They cause most crashes!
Try you sons antena in your TX for a test. Some times the antena looses contact between joints , then when it is colapsed and pulled back out it is OK , They get that way when people try to clean them or lube them maybe natural wear.
