RE: Hog Bipe Float conversion
Thanks for chiming in Ed. Power comes from an OS 61FX. It really hauls in the air and gets off the ground in less than 30ft. Do you recommend a specific brand of floats? Weight is about 6-7lbs all up. I have the covering stripped atm, so it is feasible to make the structural mods you mentioned behind the wing saddle. I was thinking the same thing since the lower wing is fairly easy to mount up. As for waterproofing, do you bag your Rx? or anything in the plane?
