OS 91 FS II Problem
Hello all,
I have an OS 91 FS that I bought brand new last fall, that now has about 1 1/2 gallons of fuel thru it. well my problem that I now have is, while I was flying today the engine died and I had a succesful deadstick landing, well after I refueled it I was going to make some adjustments to the fuel mixture, when I went to turn the prop back to the backwards stroke to use the started I soon found out that there wasn't any compresion on the engine! Is there anything I can do to fix this or should I send it in for service, it should still be under the warranty?
Thank you
Tony
