RE: Battery help needed
As a minimum:
Two 2200Mah batteries reciever, and one 1200 Mah ignition. Each through a separate switch, as you stated.
NiCads are fine, but a little heavy - 4 cells direct or 5 cells with a regulator. Nimhyd are a little lighter, and Lithiums will be very light.
The sky is the limit from there, but these are the minimum recommendations.
CJ
