RE: Slow Stick Batteries
That should be ok. The SS will accomodate a wide array of batteries because they attach by rubber bands ,velcro, or whatever to the bottom of the fuse. It's designed so that the battery can move around so you can adjust the CG depending on the weight and shape of the battery you're using.
Steve
