RCU Forums - View Single Post - U-Can-Do 3d 46?
Old 08-13-2004 | 05:07 PM
  #1099
Dylwad
Default RE: U-Can-Do 3d 46?
I would bet that the .51 and the 10x6 prop is the culprit. try an 11x4, 12x4 or 12.25x3.75 prop, that 10x6 at 12000rpm is producing about a 70 mph pitch speed, where most of the people flying this plane are using a 4 inch pitch prop maxed around 10000 rpm, which gives you around a 40 mph pitch speed. If your elevator linkages arent perfectly slop free, and your servos are sloppy around center, maybe combined with a non sealed hinge gap and no reinforcements, anything over 35-40mph would probably introduce flutter, and rip the elevator off. by changing to a bigger, lower pitched prop you gain alot of thrust and lose the speed~which this plane was designed for.
Half throttle may be producing a higher speed than you think with that 10x6.
Dylan
ORIGINAL: hobby_man
I have had two Horizontal stab's break off on this u can do 46. The first flight broke it off at 1/2 and the second flight at 1/4 throttle broke it off.
the plane has a super tiger 51 ringed and a 10-6 prop
I have 20 years in this hobby and I cant figure out what is wron.
see picture
Any ideas????
