RCU Forums - View Single Post - nitro engine tweeks
Old 08-14-2004 | 01:59 AM
Frost_'s Avatar
Frost_
Default RE: nitro engine tweeks
Listen to what gubbs said about just polishing, you don't want to inadvertedly affect the flow in and out...
About your shim question, the higher Nitro you go, the more chamber volume you need to prevent pre-ignition or detonation. Most stock engines (car and truck) will run 20% but not 30%, without an additional head shim or 2....
