RE: Is this Tam's pipe safe to use?
Thanks...Yeah Buck, I am installing servo extensions and air plumbing tonight.
I thought it'd be OK but best to ask.
HotelSierra, I'd like to go to Fresno and that is my backup plan if i don't get it done in time for GSW. Trim scheme and paint details won't be complete but at least it'll be in the air.... also, do your pipes extend past the rearmost formers (in the tailcones)? Mine seem to be about 1/4" short, and I'd like to keep the P120 as far forward as I can for CG purposes.
I had to grind away quite a bit of the double internal formers at the stab mounts, until the width of the inside edge of the formers (just above the stab mount block) is only 1/8". Even then, I have to squeeze the pipes (as you mentioned).
Barry
