RE: Cowl cut-out for DA50
You can cut around the exit tubes in a square and run the spark wire between the stacks without cutting all the way to the back edge. That is how I did it but I had to shorten the exhaust tubes a bit to allow the cowl to slide on and off. I'll try to take a picture and post it so you can see what I mean. Just a thought.
