RE: Cessna 182
I agree with fiveoboy01, you are not letting it get up enough airspeed and have too steep an angle on climb out.
All you should have to do is advance the throttle SMOOTHLY to full throttle, let it build up speed, THEN give it A LITTLE up elevator. The plane will lift off when it has enough airspeed and be in a gentle climb out.
