RCU Forums - View Single Post - cant get my engine started
Old 08-16-2004 | 12:41 PM
steve69
Default RE: cant get my engine started
on the main needle it just needs to be fairly close, I made a mark on the end with a permenant marker so I could see how far round I went just as an indication,
the low side adjustment (the one inside the centre of the carb barrel (sp) is fairly important and does need to have the engine/carb out to get it accurate as per the instructions I posted earlier,
If it helps I have just measured mine, with the carb FULLY closed it is 3 1/4 turns out, but it is best to remove so you can do it as per instructions as it could be yours may be slightly different.
Let us know how it goes.
Steve
