RE: Cowl cut-out for DA50
Just to throw this in and I am sure Tom will agree, the first time you hover it get some air under you and do it high enough that if it is going to get hot give yourself some recovering room. Don't come by and yank the nose up 5 feet off the deck. I know it is not easy to hover a plane way up but that is not what matters. Keep the nose up and chase it around if you have too. Try to get it hot and if it never hesitates than you are fine. I hover around for about 30 seconds and then stick it wide open and see how it pulls out. If it sags then rich the needle a hair.
Take it easy,
Norman Ross
