RCU Forums - View Single Post - Homemade FMS Interface problems
Old 08-08-2002 | 04:27 PM
OldGuru
Default Homemade FMS Interface problems
...except for the second resistor. Do you know which side connects to which pin?
Do you refer to the additional resistor? If you do, there in no meaning to a side here. Anyway you add the resistor should work the same.
And should I be able to get a current to pass through the transistor?
I believe that you should. It may be pretty small though.
Also, please take a look at the troubleshooting section in the following link, it may not be the cable itself but some others settings on you computer (not only FMS settings):
http://www.tmac.asn.au/fms_free_flight_simulator.htm
Hope that helps,
OG.
