ORIGINAL: George-RCU
Kenny, a Matchbox is the way to go if you're not going to get a "reversed" servo. Sean's suggestion of crossing the steering wires will work also if you can do it.
George
I can't cross the lines because it is so tight in there. Also with the problems with the big hornet breaking steering lines, I want to keep it as straight forward as possible.
